585,987 active members*
4,623 visitors online*
Results 1 to 5 of 5
    Jan 2011
    171
    endmill function
    Hello
    I have been using straight fluted cutting bits predominantly until now. I now have work that would definitely benefit from switching over to a more effective spiral bit type. I understand that spiral bits cut "better" than straight fluted bits and that, generally, more flutes is better but I don't REALLY understand this. Before I start buying two or three fluted spiral cut end mills for my wood working I want to know as much as I can about which is right for me. Does anyone have some time to spare or a good link to send me to?
    35538
    Re: endmill function
    Actually, for wood, more flutes are not better. You'll almost always want to use 2 flute bits, unless your cutting plastics or aluminum, where 1 flute bits are often a better choice.
    Three flute bits can be used for wood with very high feedrates, but few smaller machines are can use them effectively.
    What will you be using them for?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2011
    171
    . Thanks. I have a larger machine. Its a four by 8 with a 6 horsepower spindle that maxes out at about 18,000 rpm. I want to use the mill to cut plywood sheets and strand board sheets. Until now I've really been in the business of carving. So, I'm not very familiar with common processing of sheets and boards like this.
    35538
    You want to use a compression spiral. Plywood is hard and abrasive, so I'd look at a chipbreaker compression spiral.
    Vortex Tool: Two Flute Upcut & Downcut Spiral (with chipbreakers) - Series 3400
    Vortex Tool: Xtreme Performance Compression Spirals w/Chipbreakers - Series 3400XP
    I'd try a 3/8", and start around 400ipm at maybe 14,000-15,000 rpm.
    Gerry
    Nov 2014
    6
    Forgive me if you know this, but compression is good because you get a clean edge from the down spiral, and the bottom up spiral keeps it from cramming everything on the floor of the cut. Yes, they're expensive, but so is your time.
  1. OEM M function on Heidenhain?
    By doubravacek in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-30-2011, 02:30 PM
  2. Want to buy 1/16 endmill .375 loc
    By elsocal in forum Want To Buy...Need help!
    Last Post: 12-16-2010, 11:13 AM
  3. Can I still use this endmill?
    By Kingjamez in forum Benchtop Machines
    Last Post: 11-07-2010, 01:02 PM
  4. function of the Z axis
    By jochesfor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-11-2008, 08:06 PM
  5. what is the G52 function
    By glovebox20 in forum Haas Mills
    Last Post: 04-25-2008, 04:07 AM
