585,749 active members*
3,885 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > electronics for cnc router. Keling?
Results 1 to 5 of 5
    Apr 2014
    3
    I will be building cnc router, r&p, 48 x 96 and I am researching for good electronic kit for the build.I will probably stay away from cheap ebay gear from China.
    I came across that kit from Keling/Automation Technology:
    NEMA34 1200 oz-in Stepper Motors 3 Axis CNC Kit (110VAC/220VAC): (3) KL-8070D Digital Driver, 24- 80VDC, 7.0A Bipolar Driver (3) NEMA34 -1200 oz-in Stepper Motors (1) KL-7220, 72V(No load), Max 20A,Unregulated Power Supply, 110VAC/220VAC (1) C10 Breakout board, E-Stop or Limit Switch can be wired, you can update to C11 or other board (1) 5V Power Supply for Breakout Board 110VAC/220VAC -
    (not sure about inductance of these motors)
    I would like to ask if anybody has experience with this kit.
    Alternatively I could get NEMA 37 kit from CNC Router Parts (more expensive) or order electronics from Gecko.
    I will appreciate all advice.
    May 2008
    1185
    Re: electronics for cnc router. Keling?
    Do you know the RPM range of a 1200 oz stepper at 70V
    youtube videos of the G0704 under the name arizonavideo99
    Feb 2004
    1086
    Regardless of where you purchase your electronics, for a rack and pinion based system you will almost certainly want to drive the gantry with a motor on both sides. This helps avoid racking, and puts more power behind the largest moving mass on your system. So I'd make sure you're looking at 4 axis electronics kits.
    Best regards,
    Ahren
    CNCRouterParts
    Apr 2014
    3
    Quote Originally Posted by arizonavideo View Post
    I don't. I know only specs that I got from the vendor.
    Apr 2014
    3
    Quote Originally Posted by ahren View Post
    CNCRouterParts
    That's what I thought. I saw other people using four motor kit for r&p routers. It's just something that vendor recommended so I thought I would ask about these motors.
    I was checking your website and I was going to send you an email asking about some components for my machine. I just need to make a drawing so I can explain better what I need. I plan to weld my machine from steel instead using extrusion but I would like to use some of the hardware you sell such as linear motion parts, motor mounts etc.
    Now I am trying to figure out what would be good electronics kit for the machine.
  1. Replies: 0
    Last Post: 11-12-2013, 12:26 AM
  2. Need help with my electronics for a DIY CNC router
    By saalih in forum DIY CNC Router Table Machines
    Last Post: 08-01-2013, 05:49 PM
  3. Gecko 540 + Keling Power Supply + Keling Steppers - Good combo?
    By metricmike in forum Uncategorised MetalWorking Machines
    Last Post: 11-19-2010, 09:53 AM
  4. Keling router on E-bay
    By ibrich in forum Automation Technology Products
    Last Post: 08-03-2007, 03:14 AM
  5. Keling Technology CNC Router Opinions?
    By meat in forum Commercial CNC Wood Routers
    Last Post: 02-24-2007, 04:06 AM
