Re: DYN3 Digital Inputs (Can I wire them to accept 24V as the signal?)
Originally Posted by
alan_3301
Can you tell what is the purpose of the zener diode in the illustration?
They act as a normal diode unless the reverse voltage is high enough, then they let current flow (from a few seconds reading)
It is wired in reverse polarity in the illustration, I'm guessing it's to stop interference/low voltages from activating the input, Only a voltage larger than the breakdown voltage will make it to the optocoupler.
and the resistor is to limit current to the optocoupler?
That is basically how it is used, the thing that does not make sense is the reverse diode on the 24vdc input (upper dwg), it would appear that it would block 24v from the opto inputs?
Al.
Albert E.
