586,029 active members*
2,931 visitors online*
IndustryArena Forum > CAM Software > SheetCam > draft sight export
    Oct 2014
    15
    draft sight export
    i am trying to export a file from draft sight in order to read it through sheet cam.
    when exporting it defaults to .dwg sheet cam is not recognizing this. it offers a long list of .dxf and .dwg extentions but can't seem to get sheet cam to recognize any of them...
    Oct 2010
    156
    Re: draft sight export
    Back when I was using Draftsight (now using QCAD), I could save in different versions of DXF and have SheetCam read without problem. I guess just make sure you're selecting an ASCII version of DXF while saving in Draftsight and also make sure you are specifying DXF in SheetCam when importing. I usually get an message in SheetCam when I try to open an DXF when I didn't change back from Gcode import, but SheetCam offers to switch to DXF and all imports OK.
    Also, you can config Draftsight to default to save in DXF format, too. You wouldn't have to change every time you save a new drawing.
    HTH
    Paul
    Oct 2014
    15
    that was the ticket. thanks for the input!
  1. Coolant sight gage
    By SpruTormaCam in forum Tormach Personal CNC Mill
    Last Post: 07-02-2020, 03:47 PM
  2. Draft Sight Activation
    By grandpa jay in forum Uncategorised CAD Discussion
    Last Post: 10-24-2014, 08:18 PM
  3. Machining a new sight for a firearm
    By ulterior_motive in forum North America RFQ's
    Last Post: 12-15-2013, 09:38 AM
  4. looking for a draft horse or team of draft horses
    By glaciallakesmfg in forum MetalWork Discussion
    Last Post: 06-07-2013, 04:45 AM
  5. RFQ - Rifle Sight
    By Flatnick in forum Employment Opportunity
    Last Post: 11-13-2007, 07:23 PM
