586,005 active members*
4,946 visitors online*
Results 1 to 4 of 4
    Mar 2011
    68
    DMG DMC 635V Open Door
    Hy everyone,
    I have an DMG DMC 635v Ecoline, I programm it with G-code, and I have a problem, even if I put M0 M1 or M30 at the end of the program the door will not open for helself.
    I want to know what to put at the end of the program for the door to be open when I finish the programm.
    I want this because when the program is finished sometimes I must push almost 15-20 times on the "Open door" butoon from the panel to open the door.
    Please I really need a help.
    Apr 2002
    5003
    At my 63V I can open the Door with M29. That pauses the program and after closing door and pressing the start button, the prog continues.
    Mar 2011
    68
    Thanks,
    I will try this Monday, and I will be back with an answer.
    Oct 2012
    2
    Re: DMG DMC 635V Open Door
    i have the same problam whit DMG635V ecoline. if anybody knows what can be done, it would be helpful.
  1. Door open request
    By zippyd in forum Daewoo/Doosan
    Last Post: 05-09-2016, 11:25 AM
  2. VF2 Run program with door open !!
    By don42970 in forum Haas Mills
    Last Post: 05-24-2011, 06:16 PM
  3. Door Open
    By North Forty in forum Haas Lathes
    Last Post: 09-02-2010, 04:46 PM
  4. 2216 FX Run spindle with door open???
    By Chuck Pressure in forum Fadal
    Last Post: 10-26-2009, 03:26 PM
  5. TL-1 door open alarm won't go off!
    By donsbad89 in forum Haas Mills
    Last Post: 09-25-2009, 04:01 AM
