584,802 active members*
4,939 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Difference between WJ200 and X200 VDF
Results 1 to 2 of 2
    Aug 2010
    278
    Can someone tell me what the big difference between the WJ200 and the X200 VDFs from Hitachi are. I am about to buy one other the other depending. I am trying to run them with a Chinese 2.2kW 4 bearing spindle. ER20 collect.
    Hive 8 - G0704 CNC Mill - 20 inch Telescope - High Resolution 3D Printer - Lasersaur 100W CO2 Cutter / Engraver
    Feb 2007
    711
    Re: Difference between WJ200 and X200 VDF
    price and features, you can read all you want about them both. Hitachi variable speed drives, inverter drives, Hitachi inverters, variable speed drives
    the x200 was replaced with the NE-S1 series.
    I saw your posting in the minimum speed thread, and I am too curious about which vfd would be best for this, when my chinese vfd takes a dump.
  1. HITACHI X200 settings
    By 15mgtar in forum DIY CNC Router Table Machines
    Last Post: 03-29-2015, 12:48 AM
  2. possible Problem with Hitachi x200 vfd
    By jayty97 in forum DIY CNC Router Table Machines
    Last Post: 09-18-2012, 08:08 PM
  3. Hitachi X200-022-NFU
    By kolias in forum Open Source CNC Machine Designs
    Last Post: 05-13-2012, 02:26 AM
  4. Hitachi X200 VFD Questoins
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 04-21-2012, 05:41 PM
  5. Hitachi X200?
    By fritts in forum Phase Converters
    Last Post: 12-27-2008, 04:06 AM
