Hi
Just started working on Mazak and I have a few things I want to change to make my life easier.
When i push MDI i can easaly use laser measurement why isn't there a tool eye measurement aswell? I would like to add this if possible, now i jump between programs to run a simple measure cycle on tools when i change insert.
That MDI function is prolly the best thing i like about the control if i can add things to it.
Also M codes for coolant isn't correct so i would like to change them aswell. This is for Mazatrol programming.
Any possibility to add M01 after each cycle or before each tool change as standard in the Mazatrol program? It's just a good way to be able to stop the machine when it's done if i need to leave the machine, programming it in manually isn't really an option, both Fanuc and Okuma has this as standard why not Mazak?
When using "Tool eye" to measure tools why doesn't it 0 out wear? And when using program to use "Tool eye" it only compensate on wear. Been looking in the parameter books for adjusting this but can't find anything.
Machine Mazak 650-II H with Matrix.
