585,719 active members*
4,120 visitors online*
Results 1 to 2 of 2
    Apr 2015
    1
    Copper Sulfate in Laser cooling
    Are the biocides used in Computer Water-cooling safe to use on the laser tubes? It's meant to prevent algae or scale from growing in the water or tubing.
    The ingredients in it is just 95% DI Water and 5% Copper sulfate. It is put into the water at 1 drop per Liter of water, so its not very strong.
    Feb 2009
    6028
    Re: Copper Sulfate in Laser cooling
    As long as there is only plastic or stainless fittings. Di water and brass or other metals can get pretty ugly.
  1. Copper laser cutting machine
    By welly2000 in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2015, 01:55 AM
  2. Laser etching on the copper object
    By esmondperry in forum Videos
    Last Post: 03-06-2013, 09:04 AM
  3. PC cooling radiator for laser?
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-17-2011, 03:52 PM
  4. Laser Cooling water
    By pete00 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-10-2009, 08:21 PM
  5. Cooling laser tube with antifreeze
    By bibi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-26-2008, 08:50 AM
