585,702 active members*
4,516 visitors online*
Thread: Coolant
Results 1 to 5 of 5
    Jul 2013
    12
    Coolant
    Hi.
    I have a new Haas VF2SS and run mostly 5xxx and 6xxx aluminium and Pom-plastic, and ocationaly a part in stainles steel.
    Wich coolant do you use and what do you recomend, what are your experiences, my machine seller recomended a mineral oil based emulsion coolant but its greasy and messy, so if there is a good alternative I want that instead.
    Thanks in advance for you help.
    Fredrik
    Mar 2008
    638
    Re: Coolant
    I'm a fan of synthetic coolants. Lasts far longer and doesn't smell bad. Only drawback that I can see is you can't tap as well. We use Castrol's Sytilo 9954
    Feb 2011
    212
    Re: Coolant
    I have found that Castrol's Mb50 is the best I have used to date. it is not greasy and it does not get stinky. after 6 months of use I only had to add 3 gallons of coolant to keep the levels at 8 or above other than that just add water every other day .
    hands down the best I have used
    Jul 2004
    100
    Re: Coolant
    Like the two replies before mine, I use synthetic also. I have been using 9954 for years. It doesn't have any bio problems and tramp oil won't mix at all. My distributor says it is for ferrous and stainless and says there is another grade more for aluminum (I do a lot of aluminum) and implied that the 9954 will stain aluminum, but I have not see any of that. The stuff isn't cheap and I keep a 10% level in all my machines, VF2, HiT18 and the cold saw. I even keep lab wash bottles of it on the bridgeport and engine lathe for spot use.
    Over the years we have gotten pretty good at rinsing our chips to reclaim as much of it as we can. We add water to the Haas with a watering can through the discharge horn. Chips will go in a big plastic tub with drain holes that sits in a tub without holes. We water the chips with a watering can and then use the draining for make-up. This make up water is about 2%. That is quite a savings!
    Regards, Ray
    ​"There is no such thing as a gun free zone."
    Ray Brandes, Ray-Vin.Com, PCB, FL 32408 USA
    Jan 2004
    539
    Re: Coolant
    This is what I switched to about 5 years ago. I really like it.
    QualiChem XTREME CUT 250C: Metal Fluids
  1. Replies: 0
    Last Post: 12-26-2013, 04:26 PM
  2. Looking for the right Coolant
    By JoshKY in forum Haas Mills
    Last Post: 08-12-2011, 01:06 AM
  3. Coolant Help!
    By stang623 in forum MetalWork Discussion
    Last Post: 01-02-2009, 08:45 AM
  4. Coolant...Which and why?
    By ajl6549 in forum MetalWork Discussion
    Last Post: 12-08-2008, 03:02 PM
  5. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
