Under the heading of Drilling cycle, I would think that a PCD drill cycle would be of great help.
A lot of my drilling work revolves around
Pitch
Circle
Diameter.
Also, while we are at it, does anyone else (apart from me) use Metric?
I have mentioned this one to Tormach, who have replied.
The resolution in step mode is 10.0mm, 1.0mm, 0.1mm and 0.01 movements.
Which while it's not bad, but if I switch to G20 I can get down to 0.0001" resolution, almost 4 times more accurate.
They did say that 0.001mm is below the resolving power of the stepper motors, but would look at 0.025mm increments and drop the 10.0mm step!
On another issue....
The reason I ask is that when using Mach3 you had no option but to enter tool lengths in Imperial(inches).
Now for some reason, before updating to V1.9 I was able to MDI G21 and find that my offsets were in Metric (1.123) 3 decimal places.
Now I find that my list of offsets are in imperial and 4 decimal places.(the offsets I did have in there have been converted).
I'm positive(i know I did) i entered the data in as metric, and of course observed 3 decimal places in the offsets.
Anyone else having this problem??
Have a great day!
