CNC Quill Kit, Elrod Macine
This is a new never used Elrod Machine Quill Kit.
Installation was started on an old 2 axis cnc knee mill when it was discovered there was a problem with the quill casting. We replaced the whole machine with a series 1 Bridgeport and didn't need this quill kit. It has been sitting on a shelf ever since. More images are available at http://www.grifftek.com/craigslist/elrod_quill_kit/
If you have questions please ask. Please make an offer on this piece of hardware if you can use it. I also have many servo and stepper motors that can be used with this kit, please inquire.
First image is a stock photo, you will not received a white powder coated unit, you will receive the items in the rest of the pictures on the link above.
From the Kurt web site:
Manual Pull-Type Vise, 8"
Part No. PT800A
Price: $2,515.00 USD
The AngLock PT-Series vises offer high precision
function through these important design features:
The original, time-proven Kurt AngLock design prevents
parts from lifting upward under heavy clamping loads.
The pull-type jaw clamping reduces stationary jaw
deflection by at least 80% as the movable jaw is "pulled"
into the stationary jaw and not pushed like standard
screw type vises.
Features:
Pull-type clamping means high precision and
repeatability.
Up to 20,000 lbs. precision clamping force.
Can be mounted upright or on either side.
CNC style allows compact spacing.
Both sides ground square to within 0.001" with base
and top.
80,000-PSI ductile iron body.
Matching of bed height 0.001" available at an
additional cost.
Matching of the keyway to the stationary jaw 0.001"
is available at an additional cost.
List Date: 7/28/2014
For more info, click here to view the original listing: CNC Quill Kit, Elrod Macine
On Sale For: $1050 + Shipping TDB
