CNC Machine
Mill info:
Purchased in 2010 New from IH CNC (Now Charter Oak automation)
<200 Running hours
New upgrade spindle in 2012, has less than 10 hours
Mill was used with full flood coolant when it was in use.
A wide variety of end mills, collets, vices and accessories as a package deal if desired.
An older version of: http://charteroakautomation.com/our-productx/manual-bed-mill/
Specs:
Working envelope details:
Total travel (Volumetrics): 6,864 in
X-Axis ( Longitudinal table travel 26"
Y-Axis (cross table Travel) 12"
Z-Axis (Quill Retracted) 22"
Quill Travel 4 3/4"
Table Details:
Table work surface (linear) 39 1/2" x 9 3/8"
Table work surface (Areal) 370.3125 in2
T-Slots: 3 slots, 5/8" each
Spindle Motor Details:
VFD upgrade power: 3 HP
VFD upgrade max speed (RPM) 3,600
Spindle and quill details:
SpindleTaper: R8
Spindle Center to Column: 12 1/2"
Spindle to Table (Min, Quill Retracted): 3"
Spindle to TAble (Max, Quill Retracted): 22"
Quill Diameter: 3"
Miscellaneous Details:
Head Rotation: +/-90 degrees
Power Requirements: 220-240V AC, 50/60Hz single phase
Lead Screw Measurements/Dials: Imperial (Inches)
Weight: 770 lbs.
Required Floor Space for Max Travel: 90" H (with stand) x 87" W x 38" D
Price is negotiable. Pick up only. Everything in pictures are included.
If you have any question please feel free to call or text me at
617-895-6518
List Date: 10/30/2014
For more info, click here to view the original listing: CNC Machine
On Sale For: $7000 (Local Pickup Only)
