585,733 active members*
4,948 visitors online*
Results 1 to 4 of 4
    Oct 2014
    3
    Re: CNC GANTRY SIDES
    Could you furnish me me all the details of your cnc 8020 base. List of materials, length, etc. following that I'll purchase these
    Bruce Connally
    Woodone US Corporation
    Bruce, that ebay is old. Here is new ad.CNC Router Gantry Sides 1 2" Thick Al | eBay.
    I am posting a print that gives you an outline of how big the router is and some of the materials used. This is not a full blown set of plans, and I am not offering plans right now. What is offered is a solid
    model that is included with the purchase which will help you build the router.( you will need a CAD program to view) The router uses 8020,thk 25mm rails, custom aluminum parts, and materials from Mcmaster Carr. The stepper motors and driver I bought from Xylotex.Mach 3 was used to operate the router.Lastly this router was designed in a way so it could be made longer or shorter.
    Regards, Brian BrantAttachment 255012
    Oct 2014
    3
    Great response Brian. Thx
    Bruce Connally
  1. PCB drilling - Both sides?
    By goaran in forum PCB milling
    Last Post: 07-23-2010, 09:51 AM
  2. Gantry: planning to design moving open gantry
    By rdcd in forum Mechanical Calculations/Engineering Design
    Last Post: 11-14-2009, 10:52 PM
  3. same cut, both sides... please help
    By grdnanthy in forum MetalWork Discussion
    Last Post: 01-27-2009, 05:14 AM
  4. Gantry Sides
    By rocks101 in forum DIY CNC Router Table Machines
    Last Post: 02-16-2005, 03:18 AM
