584,826 active members*
5,118 visitors online*
    Nov 2013
    5
    Citizen A32 Rotary milling.
    Does anyone have a functional program example of C axis rotary milling I could draw from to use on my Citizen A32 machine?
    Thanks!
    Sep 2011
    261
    Re: Citizen A32 Rotary milling.
    This is from a L20, but it should basically be the same.
    This is for milling a Torx (hexalobe) in the sub spindle. The business end of things are
    M48C0 (starting index angle)
    X0 (because it was done in the sub and the middle was pre-drilled. This could be above stock diameter if you want to be safe)
    G12.1D0E=C (activate polar milling)
    G17 (select g2/g3 plane)
    ===== Hexalobe milled in sub =====
    M48C0
    X0
    G12.1D0E=C
    G17
    G42G1X.1134Y0F30.
    #100=0
    WHILE[#100LT.12]DO1
    #100=#100+.01
    G1Z#100F5.
    G3X.1307Y-.0401R.0551F12.
    G2X.1001Y-.0932R.0315
    G3X.0307Y-.1333R.0551
    G2X-.0307Y-.1333R.0315
    G3X-.1001Y-.0932R.0551
    G2X-.1307Y-.0401R.0315
    G3X-.1307Y.0401R.0551
    G2X-.1001Y.0932R.0315
    G3X-.0307Y.1333R.0551
    G2X.0307Y.1333R.0315
    G3X.1001Y.0932R.0551
    G2X.1307Y.0401R.0315
    G3X.1134Y0R.0551
    END1
    G40G1X0Y0F20.
    Z-.1
    G13.1
    And here is some code from an L20 milling a .375 hex on a .500 bar. The attached print shows Point 1,2,3 ect (P1,P2 ect in the program)
    M5
    (MILL A .375 HEX WITH .05R CORNERS)
    T1100(Live face mill/.375" cutter /1/2"bar)
    M18C0
    G98M59S3=1200(GSE1110 is reverse rotation)
    G50W-.375(SHORT-TOOL)
    M131(Y axis mirror image oN)(if not T11-13 then M131 not needed)
    G0X.95T11
    Z.3
    G12.1D0E=C
    G17
    G41G0X.1875Y.25(P0)
    G1Y-.1083,R.05F8.(or use G2)(P1)
    X0Y-.2165,R.05(P2)
    X-.1875Y-.1083,R.05(P3)
    Y.1083,R.05(P4)
    X0Y.2165,R.05(P5)
    X.1875Y.1083,R.05(P6)
    Y.05
    G40G0X.45Y0(X.45 = .1875 + .1875 +SOME)
    G13.1
    G18G99M60
    M132(Y axis mirror image oFF)(if not T11-13 then M132 not needed)
    G50W.375
    G0Z-.05T0
    CNC Product Manager / Training Consultant
    Nov 2013
    5
    Quote Originally Posted by MCImes View Post
    M48C0
    X0
    G12.1D0E=C
    G17
    G42G1X.1134Y0F30.
    #100=0
    WHILE[#100LT.12]DO1
    #100=#100+.01
    G1Z#100F5.
    G3X.1134Y0R.0551
    END1
    G40G1X0Y0F20.
    Z-.1
    G13.1
    M5
    M18C0
    G0X.95T11
    Z.3
    G12.1D0E=C
    G17
    G41G0X.1875Y.25(P0)
    X0Y-.2165,R.05(P2)
    Y.1083,R.05(P4)
    X0Y.2165,R.05(P5)
    Y.05
    G13.1
    G18G99M60
    G50W.375
    G0Z-.05T0
    Thanks a bunch for reply with sample prog. i have another question if you have ever used genswiss milling attachment to mill on sub spindle.
  1. Citizen l720 VIII Rotary tool holder T10 T11 T12 X Y Axis
    By Mark B. in forum CNC Swiss Screw Machines
    Last Post: 01-12-2015, 01:55 PM
  2. Milling pb on Citizen L25
    By novaecaine in forum CNC Swiss Screw Machines
    Last Post: 01-15-2014, 03:48 AM
  3. Helical Milling Citizen L632
    By chet470 in forum CNC Swiss Screw Machines
    Last Post: 12-30-2010, 01:01 AM
  4. Citizen L20 Thread Milling
    By Ovrclck350 in forum CNC Swiss Screw Machines
    Last Post: 04-01-2010, 04:32 AM
  5. Milling with a Citizen C16
    By Koalas in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-22-2005, 08:22 AM
