585,991 active members*
4,725 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > chuck unclamp m code m13 didn't worked in macpower cnc with fanuc oimate td control
Results 1 to 5 of 5
    Mar 2015
    10
    i want to know does chuck unclamping/clamping mcode needs to be activated through any parameter on macpower cnc with fanuc oimate td control??if yes then how??
    Aug 2011
    2517
    Re: chuck unclamp m code m13 didn't worked in macpower cnc with fanuc oimate td contr
    chuck unclamp/clamp is normally M10/M11
    Mar 2015
    10
    but on my machine its mcode is m13!
    Feb 2006
    1792
    Quote Originally Posted by cnchelp9006 View Post
    How can you be sure if it does not work?
    If it was earlier working, there can be some hardware problem.
    If it never worked, it was possibly not implemented by the MTB. Contact them.
    Aug 2011
    2517
    there is no activation via parameters. either it works or you are missing the required hardware and the function is not available.
    if it worked before but not now your machine has a fault.
  1. Replies: 4
    Last Post: 02-21-2014, 02:26 AM
  2. Fanuc 6T control M code help
    By motter71 in forum Fanuc
    Last Post: 02-09-2013, 09:49 PM
  3. M-code for Chuck Clamp/Unclamp
    By stuby in forum G-Code Programing
    Last Post: 01-21-2011, 04:30 PM
  4. Fanuc O-T chuck open/close M-code
    By Ztiggi in forum Fanuc
    Last Post: 01-29-2008, 01:27 PM
