585,908 active members*
3,879 visitors online*
Results 1 to 2 of 2
    Nov 2014
    1
    Angry Burr problem hypertherm powermax 65
    hello every body i need your help Please ! i have a big problem, with burr down i don't know how to liquidate i have an hyperthem pm 65
    i work Frequently on mild steel 3 mm and put the post on 45A and air on 90 psi but burr there are on metal
    i wait reply
    my regard's
    Jul 2013
    26
    Re: Burr problem hypertherm powermax 65
    Hi,Hmidet.Actually Plasma for metal cutting,there is really has burr.That is can't avoid.
    The different is burr little or more.I suggest you cut with fast speed,If your machine is good,only the start point and end point with burr.
    If there is also has this problem,kindly turn down the plasma power then text
