I have 2 DMM DYN3 drives with 750W motors. One drive consistently trips a breaker when powering up the contactors. The breakers are new (Eaton FAZ-C20/3) 20A, C curve. Do I have the wrong trip value? Should I try 20A D curve high inrush current? I have been told standard should be fine. Is something else going on perhaps? The drives are currently hooked up to 3 phase, 240v AC high leg delta, which is going through 2 buck transformers to reduce voltage to around 222 V AC to keep it below the 230v max. There is no load on the motors yet as I'm still mounting things on the lathe. Input power seems good. Also I'm using a line filter for the logic power connection and no, I'm not powering logic with the high leg
The breaker does not trip if I power the contactor then flip the breaker to on.
What do you recommend?
