Howdy All,
I've been lurking here for quite a while and have finally bought a machine for use in my garage and a little side gig working with high school kids and their robotics club projects.
2 months ago I bought a 1996 machine from the original owner. It was in pretty decent shape except a little rattle that we originally thought was just worn vari-speed bushings. Turned out to also have badly worn spindle pulley and splined hubs
Well, I replaced the hubs and installed all new bearings, bushings & belts in the top end. Spindle bearings are still original.
I'm now in the final stages of getting the garage properly situated so I can move the machine from it's temporary waypoint to new home. Should be in the next couple weeks.
Now for the meat of my post:
I would like to convert the Z axis (quill) to cnc similar or identical to the 3 axis EZ TRAKs and have some questions. I, like many others, can't afford to break the bank for this.
Hardware:
Where to get the mechanical parts, all of the parts ? I've done a fair amount of web searching and see that Elrod produces a nice looking setup, are there others. I have not contacted Elrod regarding compatibility with the original software.
Who else offers aftermarket quill conversion hardware?
Is there a source for the oem parts?
Software:
Is EMI the only source for axis boards that are compatible?
I have read in other threads that the original 2 axis software will also work for 3 axis, is this true?
If so, are there changes like jumpers to be revised on the BMDC?
I'm just starting this quest so please bear with me.
Waddell
