Would anyone help me with this dxf design for a mdf 3mm?
It would be greatly appreciated.
thank you.
Attachment 233912Attachment 233914
thank you.
If you're going through all the trouble of making this thing, why not use something more attractive than MDF, like some kind of real wood? In MDF it won't just be ugly; it will also be quite weak, in the thin sections.
Awerby thank you very much for your advices, but I plan to do this in laser, in Argentina is difficult to get other wood attractive..
In that case, use a thin plywood, which cuts easily with a laser. It will look better than the MDF version, and be a lot stronger. Acrylic plastic also cuts well that way, and would be better than MDF too.
