586,024 active members*
4,420 visitors online*
Results 1 to 2 of 2
    Sep 2013
    61
    Belt linear actuator
    Attached pics are of a PBC Linear actuator. I don't know what it's worth, but I scored it pretty cheap. The problem is, it's not a screw actuator but rather a belt actuator. It's about 4" square, 52" (maybe 54") long, and the carriage is about 11" long.
    Here's a link to the manufactures web site:
    Runtime Error
    My question is, will this work for the Y axis, or is a belt actuator a bad idea all together? My machine is 48"X44"x6" and is an all aluminum construction. I was planning on this machine being able to cut everything up to, and including, aluminum. I don't know if this actuator would be good in a machine cutting aluminum but, if it would work for a wood cutting machine, then I'm good with only being able to cut wood with it.
    Any advice would be most appreciated.
    -Michael
    Sep 2013
    61
    Re: Belt linear actuator
    It's a PBC Linear MT series actuator...if that help.
  1. Replies: 0
    Last Post: 07-27-2013, 06:29 AM
  2. MLA Mini-Actuator: PBC Linear’s Solution to Bio-Tech Linear Motion
    By Pacific Bearing in forum News Announcements
    Last Post: 05-07-2009, 07:35 PM
  3. PBC Linear Expands the PL Series by adding the PLB Linear Actuator
    Last Post: 03-06-2009, 09:58 PM
  4. linear actuator
    By coolman in forum Linear and Rotary Motion
    Last Post: 04-15-2006, 09:33 PM
  5. linear actuator
    By dgalaxy in forum Waterjet General Topics
    Last Post: 03-07-2006, 01:38 AM
