Originally Posted by
awerby
"Parting off" usually refers to a lathe operation. Generally milled parts are attached to the block they came out of by small tabs or "bridges" that hold it in place while the milling operations are being done. Afterwards, they can be cut off, either by hand, with a hacksaw, or with the mill, if you've figured out another way to keep it from flying away when it's cut loose. It's hard to talk about your part without seeing it, but yes - holding it directly in the vise can damage it, if you aren't careful about how you do that.
