585,728 active members*
4,801 visitors online*
IndustryArena Forum > Other Machines > PCB milling > AutoLeveller - the height adjusting CNC software
Results 1 to 2 of 2
    Jul 2013
    13
    First of all, apologies for this seemingly shameless promotion of my software but I think not enough CNC enthusiasts know this exists yet and this software is potentially an essential tool for creating PCB's or any etched design via a CNC machine.
    So, you have a PCB design ready for etching as gcode and you've just finished etching. Does this look familiar?
    Attachment 243376
    Large areas remain blank (bottom left) while the tool has gone too deep in other areas. There are many reasons why this might happen but essentially it's almost impossible to get a good result even with tools like a vacuum table due to warping in the board itself or an unlevel table.
    Autolevelling software probes an area first, then uses those probed results to correctly adjust the Z height according to the machines current X Y position. The result is more like this...
    Attachment 243378
    This image was taken from a PCB etched with version 0.8.0 of Autoleveller via pcb-gcode and is ~100x100mm (~4"x4")
    My website for this is Autoleveller | CNC workpiece levelling so if this sounds like something which might interest you, feel free to download the pre-compiled binary files up to version 0.7.7 and give it a whirl. If you like it, you might be interested in later versions, and for a very small price you can get an Autoleveller membership and download the latest versions whenever you need to. Plus, you will be supporting me, which will allow me to continue working on it, providing improvements, fixes, and additions.
    The main features of my AutoLeveller are...
    • Probes a workpiece and uses the information to adjust the Z height throughout
    • Easy to use GUI
    • support for Mach3 / LinuxCNC / TurboCNC
    • Works with most CAM programs or tools
    • Open source software
    • Written in Java to ensure cross-platform compatibility
    • Provides the option of writing probe values to a separate file which can be read back into the AutoLeveller for 'in-line' calculations. This allows you to resume your work from any point and even swap tool bits without the need for 're-probing'. This method also keeps the file size to a minimum
    • Automatic default probing values are obtained when a gcode file is loaded. These can of course be adjusted as needed
    • Support for both Inches and millimetres
    • A variety of useful guides are available on my site which range from a basic probe setup guide (hardware and software) to a guide for getting AutoLeveller to work on Linux systems
    • Excellent support via email and the forum, both from myself and the current AutoLeveller users <a href="http://www.autoleveller.co.uk" title="Board index">AutoLeveller</a> ? Index page
    I have many plans for future additions to this including development and integration of a more robust gcode parser, improved interface, and additional visualisation options.
    I am sure that there are people out there who would benefit from this so please visit Autoleveller | CNC workpiece levelling if that sounds like you and let me know if you have any questions. thanks.
    Jul 2013
    27
    Re: AutoLeveller - the height adjusting CNC software
    I really love this software, I just purchased it and I must say it's incredibly simple and works quite well. I have a homemade machine and it's not the most accurate thing on earth. But with autoleveller I can mill boards that look like they came off a professional CNC. It's a must for my toolbox!
  1. Autoleveller software
    By Daedelus in forum LinuxCNC (formerly EMC2)
    Last Post: 02-18-2014, 10:07 PM
  2. New Autoleveller software
    By Daedelus in forum PCB milling
    Last Post: 10-20-2013, 06:18 PM
  3. Autoleveller software
    By Daedelus in forum Mach Software (ArtSoft software)
    Last Post: 10-05-2013, 03:26 PM
  4. DT software-cut height on small holes
    By Bigrhamr in forum DynaTorch
    Last Post: 02-07-2011, 04:41 PM
  5. Techno software, adjust z height mid program?
    By andrew2 in forum Techno CNC
    Last Post: 03-28-2010, 03:28 AM
