585,982 active members*
4,606 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > attaching 8020 to existing 8020
Results 1 to 2 of 2
    greenene Guest
    I need to attach a 1x3 next to a 1x3 that is already bolted to my cnc router. The end result should be two attached pieces forming a 2x3 unit, but very solid. Essentially, I need to have these two mounted side by side. I don't have any clearance on top for joining plates, and I am concerned that placing joining plates only at the bottom will not keep these units perfectly parallel and forming one solid structure. I don't like the idea of hand drilling and bolting them together, so I am curious to know how others would approach this problem.
    thanks in advance.
    tony
    Sep 2008
    140
    Re: attaching 8020 to existing 8020
    Hi Tony,
    I don't like hand drilling either, but bolting would be the best way. 8020 sells drilling fixtures, but not specifically for the 1 X 3 [1030], but one of them should work
    or make your own.
    Larry
  1. Why use 8020?
    By DPF in forum DIY CNC Router Table Machines
    Last Post: 04-23-2010, 10:29 PM
  2. cad to do 8020
    By oneturboneeded in forum Uncategorised CAD Discussion
    Last Post: 04-23-2010, 03:17 AM
  3. What is the best way to cut 8020?
    By brihoo2k in forum DIY CNC Router Table Machines
    Last Post: 03-13-2010, 04:44 AM
  4. 8020... yup another one.
    By DEDan in forum Open Source CNC Machine Designs
    Last Post: 03-08-2010, 05:15 AM
  5. Help w/8020
    By Jcyr1 in forum DIY CNC Router Table Machines
    Last Post: 09-03-2008, 08:04 PM
