585,954 active members*
4,579 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Affordable 8mm diameter ball screws?
Results 1 to 9 of 9
    Apr 2013
    162
    I'm looking for an 8mm diameter ball screw with at least 140mm / 5.5" travel, with a compact nut. The channel in the saddle of a 9x20 looks like it can be milled out to just over 3/4" wide without compromising the strength of the dovetail. With a compact nut the sides of the channel wouldn't need to be cut straight down. Could cut through the back end of the saddle to mount an end bearing on the outside.
    I've found some sources for new ones like that but my bank account puckered up tight at the $400~600 price! For that I could buy the Thompson kit with ball screws and some motors and drives.
    Jun 2010
    4256
    Re: Affordable 8mm diameter ball screws?
    You get what you pay for.
    Have you tried eBay? Caveat Emptor of course.
    Cheers
    Roger
    Feb 2010
    119
    Jun 2010
    4256
    Just be aware that the C7 grade of ball screw is really only suitable for opening windows. The specs are really sloppy. That's why they are cheap. (C7 and up are rolled; c5 and down are ground.)
    The smaller the number, below 7, the better. Look it up.
    Cheers
    Roger
    Apr 2009
    5516
    C7 is .002"/ft, not too bad. They do make some ground screws with C7 rating though not common. Some folks rebuild them with slightly larger balls to take up slack but that requires careful sizing of balls.
    I do have in my possession a NSK ground ballscrew, 8mm dia, 2mm lead, with FK8 bearing C3 accuracy all NOS I give you a deal on.. Don't remember the travel or OAL....
    C5 about .0005", C3 about .0002"...
    Apr 2004
    733
    I have 46" travel NSK ground ball screw that is marked C7 that I bought on eBay for cheap. I plan to use it on a CNC that will be only be cutting wood. I think it should be good enough for that purpose. My guess is that it was suppose to be a higher grade ballscrew but did not pass tolerance. Anyway it probably better than the rolled Chinese ballscrews.
    Apr 2013
    162
    Quote Originally Posted by louieatienza View Post
    If it's a foot or so long I may be interested.
    Apr 2009
    5516
    What happened to the 5.5" of travel?!
    Jun 2010
    4256
    Hi Louie
    Well, maybe 5.5" of travel, plus 3" for a longish anti-backlash nut, + 2" for turning down at one end for bearings and pulley, plus a little bit at the other end to go in a loose housing, might come close enough to 12"? It's amazing how dimensions add up.
    Cheers
    Roger
  1. THK HSR Ball Replacement / Diameter
    By wado1971 in forum Linear and Rotary Motion
    Last Post: 04-24-2015, 08:59 PM
  2. ball screw diameter
    By crack in forum DIY CNC Router Table Machines
    Last Post: 12-31-2007, 05:49 PM
  3. Ball screws, Acme screws, threaded rod
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 06:39 PM
  4. Ball screw diameter
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 01-03-2004, 01:00 AM
