585,763 active members*
4,268 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Adding estop to Xylotex board
    Jul 2003
    92
    I use a Xylotex board driven via parallel port from a ThinkPad T20 notebook.
    I don't currently have an Emergency Stop wired. My notebook is right next to the CNC router, so I've just hit the RESET in Mach3.
    But I was thinking about adding a UC100 motion controller so I could use other notebooks that don't have parallel ports. But I got to thinking, maybe the reset button on Mach3 would take some time to act because the UC100 is really sort of acting like a buffer. Am I correct on that?
    So I was thinking I should wire an E-Stop, but I don't know where to place it. The Xylotex manual seems to indicate one could be wired to ENAX, ENAY, ENAZ, and ground. But it also said one could be wired to the parallel port screw terminals on the Xylotex board.
    If I wired to the parallel port screw terminals, that would be like telling Mach3 that I want it to stop, so I might have the same delay? Or does Mach3 interrupt the smooth stepper some how?
    I hope I'm getting my point across. Limited knowledge leads to unclear questions.
    dubble Guest
    Re: Adding estop to Xylotex board
    Safety signals like the reset signal is handled directly on the UC100's microcontroller, so it acts immediately when triggered, it makes the required actions and then notifies mach3.
    Jul 2003
    92
    Quote Originally Posted by dubble View Post
    Yep, I got my UC100 and tried it and sure enough, the response is immediate.
    Great product, BTW!
  1. Xylotex board help
    By CROSSHATCH in forum Benchtop Machines
    Last Post: 07-09-2008, 04:49 PM
  2. xylotex board on its way
    By gun_mike in forum Xylotex
    Last Post: 07-18-2007, 11:47 AM
  3. Limit and EStop Switches with HCNCPro board
    By dshowalt in forum Hobbycnc (Products)
    Last Post: 06-17-2007, 05:34 AM
  4. Replies: 14
    Last Post: 03-07-2007, 12:39 PM
  5. Will a Xylotex board be any different?
    By phantomcow2 in forum Xylotex
    Last Post: 10-23-2005, 02:50 PM
