Re: Acceleration Plasma cutting machine.
You will need to do a conversion. Hypertherm lists 40 miligees as all that's needed for quality cuts. But you have to keep in mind with their controller they are ramping down air pressure and amperage at the same time speed is ramping down. You wont find an ultra heavy gantry spanning 20 feet with a simple acceleration rate of even 40 (Like mach calculates ips^2). The conversion from miligee (Miligal or mGaL) to ips is pretty simple.
40mGal = 15ips2 (Mach acceleration rate of 15)
A simple metric conversion will tell you 30,000mm a minute equals 1181.1ipm (Great rapid speed), 1800 milliseconds equals 18 seconds.
Tables that use Mach can take advantage of CandCNCs DCC control that will allow the programmer to ramp down air pressure and amperage to achieve very accurate results with an air cooled plasma. Depending on the interface of the actual ANC 401 plasma system the acceleration may be great and it may give average results. It definitely sounds like it is a servo driven machine.
Now featuring Plasmaland online
