585,933 active members*
3,906 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > AC2100:Axis Drive Ready Signal Missing
    Mar 2008
    24
    Unhappy AC2100:Axis Drive Ready Signal Missing
    When we fire up our CINCI Arrow 750 with AC2100 control, it goes all the way through the axis alignment, then the last thing when the spindle is rotating for it's alignment the machine locks up and spits out an alarm. Axis Drive Ready Signal Missing, Input CR_axes rdy(100:00/32) is off. I could really use some help and thanks in advance.
    Kevin B
    Sep 2010
    1765
    Re: AC2100:Axis Drive Ready Signal Missing
    Watch drive and spindle lites when thid happens. It is telling u one is faulted.
    Sent from my SCH-I535 using Tapatalk
    Dec 2006
    584
    Mike is correct, you need to open the back door and look at the lights on the black drives at the bottom of the panel. The red light on the drives for under voltage is normal after the drive power is removed. You need to look at the spindle drive which should be on the right and see what lights are on.
    If we are to help you, you need to follow up and get back with us!!!
    Mike cncmachineservices (dot) com
  1. Spindle drive not ready
    By mike9a in forum Cincinnati CNC
    Last Post: 10-10-2017, 03:10 PM
  2. Axis "Drive Ready" Signal Missing
    By coop31 in forum Cincinnati CNC
    Last Post: 12-15-2012, 10:32 PM
  3. Bypassing NOT READY SIGNAL, Mori SL-1A
    By nlh in forum Mori Seiki lathes
    Last Post: 01-13-2011, 03:01 AM
  4. Acramatic 2100. NC ready signal on PLC output missing
    By deepforrest in forum Cincinnati CNC
    Last Post: 09-23-2010, 07:54 PM
  5. signal missing in tnc151
    By PRIOR666 in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2007, 11:20 PM
