Attachment 184058
Unboxing the machine as shipped by Stuart Duncan from Titan Machinery Central Coast NSW.
Attachment 184060
Strip down of the XY saddle
Attachment 184062
X axis stripped down
Attachment 184064
Z axis column removed
Attachment 184066
Z modification designed in CAD
Attachment 184068
Using the Roland at work to machine the parts
Attachment 184074
Y axis plate made
Attachment 184076
Checking the fit of Y axis parts.
Attachment 184070
Z assembled & ball screw fitted. Stepper motor mount tested (Not the actual stepper)
Attachment 184078Attachment 184078
Saddle machined to accept ball screw
Attachment 184080
Base attached to the stand. Z Column fitted, Y axis and saddle installed.
Attachment 184082
X axis stepper mount CAD designed.
Attachment 184084
Making the X axis ball screw mounting block.
Attachment 184086
X axis block and ball screw mount installed.
Attachment 184088
Machining the underside of the table.
Attachment 184090
Cutting the stand off tube
Attachment 184092
Machining the stand off tube.
Attachment 184094
Table fitted and X axis components mounted.
Attachment 184096
Electronic components arrived today from the USA. Some parts also from Stuart from Titan.
Attachment 184098
Mounting and wiring the components.
Attachment 184100
Electrical panel cut out and engraved with the CNC laser at work.
Attachment 184106
Electronics wired and mounted to the inside of the cabinet.
Attachment 184108
Panel fitted.
Attachment 184110
Electronics completed.
Attachment 184112
Chip tray with polycarbonate guard.
Attachment 184116
Vice cutaway and polycarb engraving.
Attachment 184118
Hossmachine spindle spanner. Thanks to Luke (cruddcnc) and Hoss for the idea.
Attachment 184124
Billet iPhone cover
