The a axis on my bridgeport is working but only moves 1 direction.if I go a- or a+ they both move as if I werr pressing a+.I have exhausted everything I know .been through all the settings I know to check.any advice would be greatly appreciated.
Check the direction wire to the driver. Probably broken, or has it never worked?
A loose or broken wire will cause that as Neil suggests. It has happened to me a few times, but I usually get intermittent travel direction. Meaning it will sometimes move left and sometimes right. Sometimes several button pushes moves the same direction.
Lee
Okay, changed motors, same problem , switched drives to check function. evrything works except which ever driver i went to still hasd one direction. using gecko drives, a smoothestepper. pmdx 126 BOB and PMDX 134 motherboard. all i can come up with now is that it has to be in the software or related to the expanded mode on the 126. has anyone else conquered this problem. i have a feeling it is quite simple( most things are when you get down to it.) thanks again-Andy
