All,
Long post, but bear with me...
I'm in the early stages of designing my second router and focusing much more closely on performance aspects after lessons learned on my first machine.
One key aspect of any moving gantry machine is the gantry beam, what it's made of, and the loads it can resist, especially in torsion. Unless you're cutting strictly parallel to the beam's long axis (or using a non-contact tool like a plasma or laser), torsional loads resulting from the spindle load inducing twisting in the beam via bearing reactions is something we should think very carefully about.
There seems to be fairly healthy debate on the Zone about 8020 vs. steel and the pros and cons of each. I read a couple days ago a post where someone asserted that 8020 t-slot extrusions are terrible in torsion compared to steel. The basis of that person's logic was that 8020 doesn't have a continuous "skin" and the t-slots greatly reduce its ability to resist twisting forces. I bought into his rationale hook, line, and sinker initially and very nearly convinced myself I should sell the 3060 (3" x 6") extrusion I just bought, go find a welder, and start fabricating a "real" beam out of steel.
Of course, what followed naturally was a study of the pros and cons of steel, and like many of you, I quickly came back down to Earth after realizing how challenging it can be for a DIY home-shop builder to deal with welding, and then straightening, steel as the basis for something that has to be fairly straight in three dimensions. I know there will be folks jumping in saying extrusions aren't necessarily straight, either. Fair enough, but I think most of those same people would agree that good quality extrusion in its natural state is likely straighter than steel after significant welding with no access to stress relief ovens or large surface grinders. And yes, I do realize "access" to those kinds of services can be either physical OR financial. Both are tough for most of us DIY types.
Back to the question at hand--8020 vs. steel in torsion. It's been many years since I worked as a mechanical engineer, but I remember enough about the mechanics of materials to be dangerous. If anything I'm about to state is inaccurate, by all means please correct me for the benefit of everyone following the thread. I decided to do the analysis to determine whether it would be worth the pain to deal with steel.
I have the benefit of having a working copy of Pro/ENGINEER 2000i, albeit a student edition from grad school. It is full-featured other than lacking certain import/export functionality that kept me from importing an actual 8020, Inc. section of 3060 extrusion. So I modeled it myself using 8020's radii and web thicknesses, leaving out only the external cosmetic grooves and the 2° drop lock feature on the slot tabs. Otherwise it's a very accurate representation of the real thing, and the CAD system's section properties calculations bear this out when compared to the numbers published on 8020's website.
For non-engineers, there are couple of terms you should be aware of before I go further:
First is the Area Moment of Inertia (aka "First Moment"): this is a measure of how well a beam made of a particular cross section resists bending in one axis. It's common to see rectangular beam specs with two MOIs: "Ix" and "Iy," meaning how well they resist bending in one direction, let's assume the "easy" way vs. a direction 90° to it, let's assume that direction is the "hard" way. Think about a piece of 2x4 lumber. It's much harder to deflect it against the wide dimension than in the thinner dimension. Without getting into the math of it, the more material your beam has farther away from its neutral (center) plane, the stiffer it will be. 8020 provides Ix and Iy values next to each of their profiles online, so finding this info is easy. For steel profiles, there are multiple online calculators that let you enter in the outer dims and wall thickness (or inner dims of the hole through the tube) to get this information.
The second term is Polar Moment of Inertia (aka "Second Moment," or "Ij"). This is a measure of the beam's ability to resist torsional (twisting) loads. While it sounds complicated, in practice the Polar Moment value is nothing more than the sum of Ix and Iy. It's really that simple. If you can get the first two, you can calculate the third one.
Final engineering geek-speak I'll share is this: the UNITS of moments of inertia are in units^4 (in^4, cm^4, etc.). That's a result of the math involved, but for rectangular beams like a 2x4, it's nothing more than a function of the first moments being a product of the base^3 multiplied by the height and divided by a constant. If you're bending in the other direction, it's the base multiplied by the height^3 divided by the same constant. Hence, you wind up with in^4. Don't let that bother you.
Having this background, now you can compare beams in both bending and torsion.
Using my 3060 extrusion section in Pro/E, I had the system provide these properties to me. I then compared the result to a steel beam of the same 3" x 6" dimensions with a 1/4" wall thickness. Here's what popped out:
Ix Iy Ij
Steel 3" x 6" Rectangular Tube, 1/4" Wall 6.3385 in^4 19.3385 in^4 25.6771 in^4
8020 3060 3" x 6" T-Slot Aluminum Extrusion (my CAD, not 8020's) 6.5164 in^4 22.0300 in^4 28.5464 in^4
Aluminum as % of Steel 103% 114% 111%
With respect to bending and torsion, the t-slot aluminum beats the steel in this particular 3" x 6" beam envelope.
By the way, for a 72" long beam, the aluminum weighs about 45 lbs vs. 87 lbs for the steel.
So far, it's a home run for the 8020, right? Maybe. On the cost side, 8020 is real loser for raw material cost, BUT once you factor in costs to weld, mill, grind, perhaps stress relieve, etc., 8020 starts looking better again. All depends on what you have access to in the way of tools and services to work with steel.
One last thought I'll throw out there before the "tastes great! less filling!" debate starts: 3" x 6" 8020 is about as big as you can buy (they do offer a metric profile that's just slightly larger in both directions). Steel, however, can be had in many more sizes, and particularly important to a gantry beam is the height dimension because that's what determines how far apart you can spread your horizontal bearing rails. The farther apart they are, the lower the loads on the bearings (assuming you have them spaced appropriately ALONG the beam as well, which eats up travel...but I digress).
Mass, vibration dampening, and rigidity are also important points to consider for a moving gantry, so feel free to offer up any lessons learned there as well. Just don't respond back with "more mass is better" because most of us have learned by now that extra mass is only better if you have motors and power supplies that can accelerate the extra mass well enough to meet your performance needs.
So I'll throw this out there for you to consider. Would love to have somebody check my math, if for no other reason than to help me avoid a mistake on my new machine.
Best regards,
Tom
