585,599 active members*
3,592 visitors online*
Results 1 to 7 of 7
    Jul 2014
    4
    21i MB display error?
    We hooked up an ethernet to our mill. After researching all we can, and checking our settings time after time, we get a 'display error' after selecting embed. We pinged the machine, and we DO HAVE communication. When we try to pull from the host, we get 'display error' on the lower left during the search. It is a Doosan with 21i MB controls. There is no alarm or code, just 'display error. Any help would be appreciated.
    Thanks, Z
    Jan 2011
    350
    Re: 21i MB display error?
    Did you check that your ethernet cable is ok? Also, re-crimp both ends just in case. These guys made this doc:
    http://cnctechservices.ca/images/FTP...ter%20Head.pdf
    I think that should help you.
    Cheers.
    Jul 2014
    4
    Our plan next, was to look into another cable just as a test. We'll try that, and I'm looking through the file you had sent to see if there is anything different with what we have done.
    Thanks, Z
    Jul 2014
    4
    Ok, tried a new ethernet, even to a different router and it did not work. I went through the file sent and all of our setting are the same. I am at a stand still with this issue. Any other thoughts or ideas on this?
    Jan 2011
    350
    Ok so you tried new cable, new router, and you did follow instructions on setting your FTP server with ftpserv software with all correct IP addresses, correct?
    2932
    Are you able to ping the PC from the Fanuc?
    Quote Originally Posted by zuluzahn View Post
    Jul 2014
    4
    I was told it did, but I did not see it myself. I'm going to dig more into it today.
    Thanks, Z
  1. Replies: 1
    Last Post: 11-24-2011, 05:02 AM
  2. Mach3 Display Error
    By novena in forum Mach Software (ArtSoft software)
    Last Post: 10-24-2011, 03:52 AM
  3. position error display
    By guhl in forum Fanuc
    Last Post: 01-28-2011, 11:10 AM
  4. Panasonic Servo Drive MBDDTT2210 Display Error 26
    By Fall in forum Servo Motors / Drives
    Last Post: 05-27-2009, 10:01 PM
  5. Display following error
    By Rocksalt in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-29-2006, 01:57 PM
