2003 HAAS TM-1 CNC Vertical Machining Center
Specifications:
Table Size 47.75" x 10.5"
Table Top to Spindle Nose 4" - 20"
X-Axis Travel 30"
Y-Axis Travel 12"
Z-Axis Travel 16"
Spindle Taper CAT # 40
Spindle Speed 0 - 4,000 RPM
Spindle Motor 7.5 HP
Max. Tool Diameter / Weight 3.5" / 12 lbs.
Rapid Traverse Rates 200 IPM
Cutting Feedrates 0.1 - 200 IPM
Electrical Requirements 3 PH/Single PH 208V / 240V
Machine Dimensions 85"x69"x109"
Machine Weight 3,500 lbs.
Equiped with:
All Available Manuals
Prewired for 4th Axis
USB Port Upload/Download
Coolant Pump Option
Rigid Tapping
Spindle Orientation
Accepts Single or Three Phase
Comes with pictured cabinet and tooling holders.
Excellent Condition
List Date: 11/22/2014
For more info, click here to view the original listing: 2003 HAAS TM-1 CNC Vertical Machining Center
On Sale For: $15,950.00 + $500.00 Shipping
Mobile friendly version: 2003 HAAS TM-1 CNC Vertical Machining Center
