585,758 active members*
4,310 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 1.2 angle stepper with encoder
Results 1 to 12 of 12
    Jan 2004
    83
    Hello,
    I asked this on another forum as well but, didnt get enough answers.
    I have a question that I cant seem to get my head around, would appreciate some help.
    I have a 1.2 angle 3 phase stepper with 1000 line encoder. This means my motor does 300 steps for each full turn. However, if I understand correctly, the encoders line count of 1000, even though it becomes 4000 count, it can not be divided by 300, so...how does this work?
    Btw, my drivers micro-stepping capabilities are 800, 1600, 3200, 6400, 12800, 25600, 51200,1000, 2000, 4000, 5000, 8000, 10000, 20000, 40000
    Thanks.
    Jan 2005
    1695
    Re: 1.2 angle stepper with encoder
    If you have a servo stepper drive, there is no need for the counts to be divisible into the steps. The stepper can be driven more or less like a brushless servo motor.
    Dec 2003
    24220
    It is called the least input increment, and a stepper can only position to what ever the step resolution is, either in full or fractional stepping, a servo motor on the other hand has a least input increment as fine as the encoder resolution allows.
    Al.
    Albert E.
    Jan 2004
    83
    So, does that mean that if my stepper can only position to the step resolution, either in full or fractional, the encoder wheel is always going to read in between two encoder lines and be inaccurate? I am speaking considering the above mentioned micro stepping capabilities of my driver.
    Dec 2003
    24220
    The encoder should give a reading of where it is actually positioned at by the motor, unless you have some kind of special stepper drive system, the stepper is almost always an open loop servo, IOW not capable of PID control as is a closed loop servo motor.
    Al..
    Albert E.
    Jan 2004
    83
    There is a video of the drive I am using with the motor. Thats not me but a very similar seetup is being used in the video:
    https://www.youtube.com/watch?v=ZMZdCcLQc4M
    In this video, the motor has high position keeping ability and it also catches steps if stalled for short periods.
    Dec 2003
    24220
    I see by your OP and the vid it uses a 3phase stepper motor which essentially is a 3phase PM servo motor.
    Al.
    Albert E.
    Jan 2004
    83
    So what does that mean for stepping? How does that effect the steppers ability to step, or microstep? How can the stepper be accurate if the step of the angle never aligns with the lines of the encoder? Thanks.
    Jan 2005
    1695
    Leadshine hasn't explained in detail how their system works, but I'm guessing it acts more like a brushless servo motor than a stepper. The controller will use the feedback from the encoder to adjust the drive current. It doesn't need to step. Read up on field oriented control, if you want the technical details.
    Jan 2004
    83
    Is there a way to find this out for sure? A way to tell, if its stepping or if its field oriented control? Thanks.
    Dec 2003
    24220
    Often these are variable reluctance motors, they can be detected by making sure the motor wires are all open and then turn by hand to see if there is no, or very little detent, if so they are V.R.
    Al.
    Albert E.
    Jan 2005
    1695
    If you are concerned about it's accuracy, tape a laser pointer on the shaft and measure the distance between steps.
  1. Encoder on stepper
    By skubajon in forum Stepper Motors / Drives
    Last Post: 12-28-2012, 02:36 AM
  2. stepper motor without encoder
    By ReCar in forum CNC Machine Related Electronics
    Last Post: 05-18-2012, 07:55 PM
  3. Stepper with Encoder
    By jcoats in forum CNC Machine Related Electronics
    Last Post: 12-10-2008, 11:32 PM
  4. Stepper with 200 cpr encoder
    By mdoan in forum Stepper Motors / Drives
    Last Post: 10-22-2004, 02:59 AM
  5. Stepper motor with encoder?
    By buscht in forum Stepper Motors / Drives
    Last Post: 07-13-2004, 03:53 AM
